Exhausting metes and bounds description
Discussion in 'Surveying & Geomatics' started by Mike Berry, Jan 23, 2013.
  1. Mike Berry
    Mike Berry 5-Year Member
    947
    Bend, Oregon
    This is the surveyor’s certificate from an early 1990s plat I ran across today.
  2. A Harris
    A Harris 5-Year Member
    4,035
    NE Texas
    That is a typical mess all thrown together to fit something where there is not enough room.
    Or as Eastwood said, a cluster&%#!
  3. The Pseudo Ranger
    The Pseudo Ranger 5-Year Member
    2,383
    I wonder if the (WHEW!) was left in by mistake. I could see someone, maybe a tech or secretary that retyped the description, putting it there as a joke, then nobody catching it, and inserting it into the drawing.
  4. agrimensor
    agrimensor 2-Year Member
    Oct 8, 2012
    53
    Davao City
    he did not even bother to arrange the entries into a table/comumn so that you could cut/copy/paste in the future for use in other softwares.
  5. R.J. Schneider
    R.J. Schneider 5-Year Member
    Jul 17, 2010
    1,026
    Houston, Tx.
    The property described..
  6. Kent McMillan
    Kent McMillan 5-Year Member
    8,055
    Austin, TX
    > [​IMG]
    That is what OCR scanning software is for. You can digitize the text by scanning and then reformat the description for legibility.
    I had a centerline description to check a few weeks ago that would have required plugging in about 120 courses by hand. It was easier to scan the description and extract the bearing and distance calls to run the calculation.
  7. curly
    curly 4-Year Member
    Jan 30, 2011
    469
    SE South Dakota
    Isn't that the main job for techs? My favorite was putting a picture of a seal in place of the engineers seal; all he did was put a red x through it, not even a chuckle!
  8. Glenn Breysacher
    Glenn Breysacher 5-Year Member
    692
    Garland, Texas
    It looks like the surveyor gave the title company a Word document and they decided to save space and re-format it for their convenience. I'm sure it was several pages long as the surveyor originally formatted it, but hey, why worry about reading that pesky description? Let's reduce it to two pages.
    It's that title company mentality. They make sure their paperwork is squared away and legible, but the survey description is the last item to be put in the title commitment, and they don't really care whether anyone can read it.
  9. sjc1989
    sjc1989 3-Year Member
    Aug 13, 2012
    257
    PLSS
    Your OCR is better than my OCR. Mine really struggles with DMS symbols.
    Steve
  10. Bruce Small
    Bruce Small 5-Year Member
    Feb 6, 2011
    911
    Tucson, Arizona
    If I read it correctly, it has a single tie to a section corner but no basis of bearings and no calls for adjoiners, so unless you stumble across his POB monument the parcel cannot be surveyed.
  11. MightyMoe
    3,339
    Notary?
    It looks like there is a notary under the surveyors signature.
    Why would that be required?
  12. LRDay
    LRDay 5-Year Member
    Aug 26, 2010
    2,138
    Sanpete County, Utah
    UT
    It can be surveyed (staked) but I'm with you that it probably can't be retraced, at least not from the info in the document.
    The only difference from this and most of the metes without bounds descriptions I see is the length. Makes you wonder if calls to markers or adjoiners were left out to keep the description small or if no markers were set. Of course with enough research and work one probably could figure out from extrinsic evidence the boundaries. There may be markers out there. Which lines are new lines and which where intended to be along an adjoiner. Unless its a new island in the middle of a large parcel then there must be some lines with adjoiners. I still see this kind of stuff on new subdivision plats (metes without bounds). A basis of bearing statement is usually there as our law requires it.
  13. MightyMoe
    3,339
    Mike stated that this is a legal from a plat, so the monuments, basis of bearings, adjoiner info, ect. are shown on the drawing. Hopefully.
  14. A Harris
    4,035
    NE Texas
    Notary?
    There was title company and group of lawyers in a neighboring county to here that for a period of time would not accept any surveyor's documents without being notarized.
    Some surveyors still practice that habit as if their own signature and seal are not sufficient.
  15. Perry Williams
    Perry Williams 4-Year Member
    2,227
    Northern NH
    Not only that, it misclosed by 0.9'.
  16. Dave Ingram
    Dave Ingram 5-Year Member
    2,187
    Shenandoah Valley, Virginia
    Notary?
    The purpose of a Notary is to witness a signature to assure that the person whose name is there is actually the person that signed. Not a bad practice given the horror stories you hear about people using a dead surveyor's stamp, etc.
    Generally I find that I need a notary when my plat is being recorded "stand alone" rather than being attached to a deed.
  17. Goddsc
    Goddsc 3-Year Member
    Mar 27, 2012
    89
    Northern California
    Not surprised. There are a lot of non-tangent curves in there using the chord bearing and distance to define them. Those rounding errors add up after a while. That is why I always use a radial bearing to define (orient) a non-tangent curve. Rounding of arc seconds introduces significantly less rounding error than rounding distances to the nearest hundreth and the radius is almost always an even number (i.e. 200.00')exactly and the delta is also to the nearest arc second.
    Also lots of places in that description for fat fingered errors.
  18. Kris Morgan
    3,361
    Andy
    All subdivision plats in the county require not only the surveyor's signature and seal, but a notary also.
    Those are the only signatures of mine that are notarized, but all are required.
  19. MightyMoe
    3,339
    Notary?
    Then how do we know the notary is the real notary that signed.
    They give us a seal and authorize us to sign surveys. Isn't that as offical as a notary's seal and signature.
    Just something we've been through a number of times with the local government types; when they think it over enough they usually see how silly it is.
  20. Marc Anderson
    Marc Anderson 5-Year Member
    Aug 8, 2010
    Springfield, IL
    The sad part is this could easily have been an attempt to simplify a pile of existing parcel descriptions that overlapped, had gaps, whatever......
    Still a mess but the origins of it could easily have been messier still.
