FEMA Elev Cert, Highest/Lowest Adjacent grade??
Discussion in 'Surveying & Geomatics' started by Dave Reynolds, Sep 24, 2012.
  1. Dave Reynolds
    Dave Reynolds 5-Year Member
    150
    St. Helens, OR
    An issue has surfaced regarding the highest/lowest adjacent grade to a manufactured home with metal skirting. The ground has been excavated about 1' on the low side to allow for home placement, but there is no fill against the skirting. The undisturbed ground starts about 2' away from the skirting. The FEMA instructions say "imediately next to the building". Where is "imediately next to" in this case?
  2. David C. Newell RPLS LS CFM
    David C. Newell RPLS LS CFM 4-Year Member
    Mar 27, 2012
    69
    Pasadena TX
    NY, TX
    The instructions for a LOMA elevation document state "..submit lowest adjacent grade(the lowest ground touching the structure).." have use same interpretation for EC's.
  3. Lamon Miller
    Lamon Miller 5-Year Member
    Aug 23, 2010
    418
    South Louisiana
    LA, MS
    Project the sides of the structure down until it touches the ground.
  4. sicilian cowboy
    sicilian cowboy 5-Year Member
    Sep 23, 2010
    1,557
    Forest Hills, New York
    Think of it this way:
    One reason they get all the elevation information (and the info about openings) is because they are worried about the hydrostatic pressure of the flood waters against the walls of the structure.
    The only place the elevation would be relevant is ......where the structure meets the ground.
