GPS and Total Station used together
Discussion in 'Surveying & Geomatics' started by yyamahayzf, Mar 25, 2011.
  1. yyamahayzf
    yyamahayzf 4-Year Member
    Mar 25, 2011
    14
    I am using a Trimble R6 using TDS Pro to set control points at the beginning, middle and the end of a job. The total distance of the job is 5 miles. After setting these 6 control points with GPS I am currently running a traverse between them. I am half way through the traverse and when i came up to the middle set and missed the points by .45 on the northing, .25 on the easting and .44 on the vertical. Is using the GPS in conjunction with the total station the right procedure when known points aren't available?
    Thanks everyone in advance for your help :-)
  2. Randy Hambright
    Randy Hambright 5-Year Member
    686
    Johnson City Texas
    No matter the brand of GPS or Total Station, I highly suspect you have some bad GPS data.
    That being said, I hope you have checked your total station and GPS against some proven baseline before this job was started.
    A simple check will head off a complicated problem.
    Randy
  3. yyamahayzf
    Mar 25, 2011
    14
    At the end of the job, we had previously did some GPS work and before setting the points with GPS and we hit the points and the bench for hundredths. When setting these control points with GPS i shoot the points 3 times and take an average over a period of time.
  4. Just Mapit
    Just Mapit 4-Year Member
    1,142
    Using GPS in conjunction with any survey you have to do some checks. Was there mission planning? Are you using RTK? (it sounds like your are)....trust your total station info more but only after the Q/A is done. RTK (if that is what you are using) can be skewed if the proper mission planning and attention to the info being produced is not given.
    GPS can be a good check to traditional methods...and vice versa. You found something...that's good....it means you checked it to another method.
  5. Brooks Cooper
    Brooks Cooper 5-Year Member
    64
    Arkadelphia, Texas
    If your measurement issues involve local multipath then you will receive those errors no matter how many times you repeat the measurement.
  6. Dave Ingram
    Dave Ingram 5-Year Member
    2,187
    Shenandoah Valley, Virginia
    Do it all the time. Works great.
    Here's an article describing how I do it:
    http://www.amerisurv.com/PDF/TheAmericanSurveyor_Ingram-TheTotalizer_November2007.pdf
    The tOTALIZER
  7. Plumb Bill
    Plumb Bill 5-Year Member
    1,240
    Scale factor?
  8. Just Mapit
    1,142
    Agreed...hence mission planing.
  9. Kris Morgan
    3,423
    One word for what you're doing "static"
    First, assuming you're in the middle of the project, are on the grid (scale factor)
    Did you make a sun shot after the first mile (two miles is a long way turning 180's)
    Were the control ponts static or rtk?
    What you're proposing is done all the time. Rtk wont cut it though. Checks need to be closer. However, sounds like it closed for a pipline. Adjust and go on.
  10. Andy J
    Andy J 5-Year Member
    1,982
    Sanibel Island, Florida
    are you creating a calibration or localization? If so, they are notoriously weak in a corridor type roadway project. Could you give us a bit more info? are these 6 control points part of a static network? did you send files to OPUS? Those errors are really unacceptable, so there has to be something wrong, don't ignore it.
  11. Joe M
    Joe M 4-Year Member
    431
    You are doing RTK or static GPS? How long are your occupations?
  12. itsmagic
    itsmagic 5-Year Member
    Aug 4, 2010
    218
    Calgary AB Can
    I've used RTK GPS and total stations on the same project many times using a user defined localization (or calibration as Trimble calls it).
    It works great.
    It is important to perform the localization correctly so the coordinate transformations between the GPS observations and the total station measurements are seamless and transparent. If It is done right you should be able to swap between using the GPS or total station equipment without effort.
    Without more information I'd guess the problem is in how the localization was done at the project outset. Problems with the quality of the GPS positions would be another guess or perhaps incorrect or mismatched prism constants.
    The TDS reference manual provides more detail about the localization process than can be readily expressed here in a few lines.
  13. Troy Cobb
    Troy Cobb 4-Year Member
    81
    Edmond, OK
    My money is on Adam.
  14. yyamahayzf
    Mar 25, 2011
    14
    I am just starting the GPS up in NAD88/83, and i am shooting the control points with RTK, and no i am not send these points to OPUS
  15. yyamahayzf
    Mar 25, 2011
    14
    What do you mean by sun shot?!? The control points were RTK.
  16. yyamahayzf
    Mar 25, 2011
    14
    I am doing RTK, my occupations are 3 minutes long with .05 horizontal, .05 vertical and 2 pdop percision. I shoot all six points and go back and shoot all six again 3X. They hold within themselves with the total station, but not when traversing down from one set to another. The average distance between traverse points are about 700 feet with 5 sec of the horizontal and 15 sec on the zenith set for the traverse.
  17. Joe M
    Joe M 4-Year Member
    431
    Do you know the difference between ground distance and grid distance?
  18. Guest
    Guest Guest
    Dude!
    You got some scale factor issues is all!
    Gps 1.0
  19. Bruce Small
    Bruce Small 5-Year Member
    Feb 6, 2011
    933
    Tucson, Arizona
    I switch between GPS and a total station all the time and I've never seen anything like that kind of discrepancy. My guess would be scale factor, or something similar.
    Except, once, I had a Phoenix file in the flash card and the total station persisted in trying to warp the Tucson data to Phoenix. The errors were obvious, but tracking them down to the stupid file took forever. It wouldn't have happened but Leica sometimes reaches across files to find data it thinks you want. The moral of the story is one file in the card at any time.
  20. Loyal
    1,797
    That's an easy one...
    You are:
    1. Using your GPS incorrectly!
    or
    2. Using your Total Station incorrectly!
    or
    3. using your PC incorrectly
    OR (most likely)
    Some combination of the above.
    Tell us MORE about where you are, what you are actually doing, canopy cover, elevations, coordinate system/projection, proceedures, software etc.
    Don't feel bad....You are NOT alone!
