1. How to get logged in to the NEW SurveyorConnect.com!
    You should have received a password reset notification at the email address you used to register your account here. If you don't receive the email, please check your spam or junk folder. If you still don't have it, please click the following link to manually reset your password. If all else fails, send us an email at support@surveyorconnect.com.
    [ CLICK HERE TO RESET YOUR PASSWORD ]
    Dismiss Notice
GPS for Boundary Surveys
Discussion in 'General Land Surveying' started by surveysc, Jan 10, 2013.
  1. surveysc
    surveysc 5-Year Member
    194
    Conway, SC
    This is a follow up from last year. Have any of you changed your opinion in the last year?
    I would like for some of you GPS Gurus to explain to me how to do property line surveys in the woods under canopy with any degree of acceptable accuracy.
    1. Is it accurate?
    2. Are the readings repeatable?
    3. How consistent is the data?
    4. Can you replace property corners with any accuracy?
    5. Is this a magic box?
    These are just a few of my concerns.
    We have a Trimble Pro XR that is over 10 years old that we use for wetland surveys and I have seen it get to within 1.0 feet with shots and they are repeatable if you use the correct methodology (shoot the same control points before each session and post process the readings just to name a couple). Of course that is only for horizontal accuracy. The elevations are too rough for topographic mapping.
    Happy New Year!!:-P
  2. RFB
    RFB 5-Year Member
    1,500
    Old Florida
    FL
    I'd use conventional methods.
    :stakeout: :totalstation:
  3. cptdent
    cptdent 5-Year Member
    Aug 19, 2010
    1,964
    Clinton, MS
    Use the GPS system to set up your 2 base control points, then run conventional in the wooded areas.
    GPS is good for locating stuff in open areas. Setting corners and locating stuff in the woods is better done with conventional methods.
    Worst case scenario is that you can only set your control points and then have to run conventional, but that still has its benefits.
  4. Nate The Surveyor
    Nate The Surveyor 5-Year Member
    4,467
    SW Arkansas
    AR
    There are 150 answers for you.
    Gimme a call.
    N
  5. dmyhill
    dmyhill 4-Year Member
    Jan 26, 2011
    833
    Bellevue, Washington
    > 1. Is it accurate?
    I find that using industry best practices for GNSS, it is faster for me to use a total station. For me, using GNSS's in that situation is frustrating.
    We are a generation back in our GNSS tech (Topcon GR3).
  6. jcoutsrls
    jcoutsrls 3-Year Member
    Jul 6, 2011
    32
    Lafayette, IN
    This is an issue we've had to drill into our field crew's head(s). Just because you get a "fixed" position from GPS in the woods (or for that matter in an urban environment) does NOT mean it's an accurate position. For example, I had the crew set control points with GPS for a subdivision, then I followed behind with conventional for actual lot corner staking. All of the points that were out in the open checked within 0.015' between GPS and conventional. The one point that they set in the woods (of course it was in a small "clearing" and the crew felt like they had sufficient clearance from nearby trees) was off by 0.09', which was not within acceptable RPA tolerances for this particular subdivision. If you're dealing with larger RPA tolerances, then by all means give it a shot. But I would always recommend double-checking with conventional if there is any possible source for multipath.
  7. Dave Ingram
    Dave Ingram 5-Year Member
    2,187
    Shenandoah Valley, Virginia
    OK - sarcasm is on
    So what? According to some posters here you can set the corner anywhere you want and once it's set it is good!
  8. surveysc
    194
    Conway, SC
    OK - sarcasm is on
    That didn't take long. I just wish some of the local guys here would look on this site and see what the experienced GPS guys say. But as they say in church, here I am preaching to the choir. Thanks guys.B-)
  9. David Livingstone
    David Livingstone 5-Year Member
    Jul 22, 2010
    538
    Macomb Illinois
    OK - sarcasm is on
    Like others have said, you can't use GPS in the woods and shouldn't try. Use GPS to set control points and break out the total station.
  10. your-other-right!
    your-other-right! 2-Year Member
    Jun 29, 2012
    69
    Athens, TN
    Line Staking
    I think it depends on what you are trying to accomplish. Are you staking the line through the woods for a fence? Or for the owner to put up no trespassing signs? or for logging? it is a judgement call. I have had pretty good success staking/flagging lines with my RTK unit in the winter time. I did not trust it at first, so I took it out to a job where we had staked a 2000' line with the total station the summer before. all of the stakes were .2' or less from where the GPS said they should be. That's about the tolerance we staked them with in the first place. Sometimes .20' just doesn't matter.
  11. Kris Morgan
    3,278
    GPS for Boundary Surveys *Sarcasm WAY ON*
    > 1. Is it accurate?
    > Happy New Year!!:-P
    1. Maybe
    2. Maybe
    3. As consistent as the wind, constantly changing
    4. Really? No.
    5. Evidently it's a box for people who shouldn't use GPS
    The Pro XR is an aweseome piece of equipment and should be used for what it was designed for. If you try to go into the woods with survey grade GPS, you MAY get the right answer, or you may not, but unless you check many times, you won't know, thereby making the profit you should have realized from the gear, spent in checking for trying something that shouldn't have been done.
    Set pairs of control, check the control, get the damn gun out, tie or set the corner, pack it up, move on. Then, near the end of the day, check the control again. Multiple shots will generate the positional tolerance you need for any feel good test.
  12. gschrock
    gschrock 5-Year Member
    Aug 23, 2010
    1,899
    The Nice Washington
    GNSS, trees, assumptions
    Given the scenario you painted, and the gear you described it almost sounded like a loaded question. Of course you'd have to use conventional.
    There are situations where GNSS can be utilized, and situations where it should never be utilized. But when it can, it can be a godsend. Gauging the difference can take a lot of hands on experience.
    It seems counterproductive to lump the value of any tool into two narrow camps of "good" and "evil". There is a lot of real estate in between.
    And a side note: assumptions about GNSS, even from a decade ago are questionable, even on such things as trees. There are new features that help in canopy situations; we've tested quite a few new ones, and each time we seem to be able to work effectively just a wee bit deeper into the woods. And when L5 gets fully deployed, watch out trees...
  13. Bruce Small
    Bruce Small 4-Year Member
    Feb 6, 2011
    876
    Tucson, Arizona
    (1) In the woods, under canopy, you cannot get accurate results, and they won't be consistent. On the other hand, if a couple of feet is good enough for what you are doing, then have at it.
    (2) You will waste so much time waiting for lock that you will give it up as a bad idea (which is good, because it is indeed a bad idea).
  14. James Fleming
    James Fleming 5-Year Member
    2,966
    Washington DC
    MD
    I use it for first floor elevations on topo surveys; but you have to run in the building real fast so you can get the shot before you lose lock.
  15. FLS
    FLS 4-Year Member
    Sep 15, 2010
    490
    UPSTATE NY
    Do not set just a "pair of control points" set 3 so you have a solid check. I have caught bad shots by doing this.
    I have used GNSS in the works to locate ledges and creeks, where 1' is accurate enough and the feature changes everyday.
    I have located long fence line in the woods using GNSS, between total station located end points of the fence line.
    I locate hedgerow and fence lines on an offset. This really saves a ton of time, especially if or on a wheeler or snowmobile.
    Remember your going to have error in your TS traverse, so if it equals your GPS location, then you've saved a lot of work and time.
    And always it all depends on your situation (sats, distance to base, terrain, accuracies needed).
    I just completed 90 percent of a 50 acre farm survey including buildings using GNSS. With hedgerows and woods.
  16. MightyMoe
    MightyMoe 4-Year Member
    2,939
    That's good advice! I should have thought of that myself. ;-)
  17. gschrock
    Aug 23, 2010
    1,899
    The Nice Washington
    GNSS, trees, javelins, bungees...
    Of course, one would need to be capable of still running that fast. Bazinga.
    You could launch the rover on monopole like a javelin in to the woods or first floor area then run after it to gain those few critical fractions of a second. takes a bit of practice.
    The addition of a bungee chord can, if carefully done, eliminate the running part, but you have to be careful with the returning rod. I suggest body armor, faceguard, breatplate, cod-piece or other protection.
  18. Marc Anderson
    Marc Anderson 5-Year Member
    Aug 8, 2010
    449
    Springfield, IL
    We have used the Trimble RTN receivers and have had extremely good results, even in foilage free trees (winter) when re-tracing previous work done by others. We stayed within Bill Henning's guidelines documents for RTN and repeated about half the observations on a different day and a different time. Everything repeated within .03' and a check to a nearby NGS monument checked .03' N-S, and .01' E-W. This was for rural landfill boundary work however.
    Conventional RTK, I'm not quite so sure about, but if I had the time to observe at a differnt day and time, that would improve my confidence.
    Most of the time it's just as fast to set up a TS and go conventional though.
  19. adamsurveyor
    adamsurveyor 4-Year Member
    1,517
    Colorado
    A thought:
    Go set your corner locations using GPS. In the treed areas (or perhaps all areas) set a hub. You can use the hubs location to help you figure out how to traverse into it using intervisible points, and traverse in using conventional methods. Set your corner, and see how close you hit to the hub. This will be a check for a gross error blunder, and can be used to see what kind of precision and/or consistency you get. Regardless of the responses you get on this "poll" you would want to build up your confidence level and/or know you limitations better anyway (I would think).
  20. jprice
    jprice 2-Year Member
    Jun 27, 2012
    24
    I have ran a lot of Large Boundary Projects using GPS as a tool 5000 t0 30,000 acres and NO you can not get reliable results in woods, No it is not a magic box but for someone who has been there here is my sugestion on how to incorporate GPS on large boundaries where corners are covered by canopy.
    First spend a few days reconing and recovering property corners. then with google map or aerial photo pick an open area near the corner or a location that you suspect might be a corner that is not covered by canopy . Set two intervisible GPS control points in these open areas.
    Then take your trusty total station an run a traverse tie to your corners.
    Once this is complete you start at one of your tied corners and inverse to the next corner on line you have traversed to. Then with the total station,transit or compass start your traverse and marking toward your ending point and carry your coordinates with you and inverse at each foresight until you reach your next tied corner on line.
    Once you have completed your traverse then take your information to the office and start plotting your deeds and accept or set the property corners.
    You will save time since I have experienced 30 minute delays in trying to get GPS positions in canopy and a lot of positions are suspect.
    GPS is a great tool but to run a large boundary in woods I suspect that to meet your state mapping standards you will need to use your convential surveying skills.
    Jerry K. Price
