OPUS and Topcon Hiper GA
Discussion in 'Surveying & Geomatics' started by chaptech_rope_stretcher, Mar 29, 2011.
  1. chaptech_rope_stretcher
    chaptech_rope_stretcher 4-Year Member
    Mar 25, 2011
    5
    St. Albans, WV
    Hi Folks,
    I am using a Topcon Hiper GA (base and rover) setup. When uploading to OPUS...I do not see an option under "antenna type" for my GA's. Which antenna type should I be using. I HAVE been choosing TPSHIPER GGD...since it seeemd to fit my units the closest. Am I missing something...or should this give me what I need? Thanx
    Jason
  2. snoop
    snoop 4-Year Member
    1,524
    I think a GA is in the same case as a Hiper Lite. Correct?
  3. Loyal
    1,688
    I suspect that the NGS simply hasn't "calibrated" this particular unit as yet (it's pretty new).
    The KEY to getting good solutions, is using the RIGHT "antenna phase pattern data." This relates not only to the case configuration, but [more importantly] the the actual ANTENNA [patch, unit, model, whatever] installed in said case.
    The Hiper GA appears to be a GPS + GLONASS unit (40 channel 10 or 20 hz), so I would suspect that the ANTENNA is similar to the HIPER Lite PLUS (also a 40 channel 10/20), but that is an ASSUMPTION! The fact that the GA has an central radio antenna (which the GGA doesn't), would make me lean towards the Hiper Lite PLUS (which does).
    I would send an email off to Topcon, and see if you can get clarification on WHICH existent Phase Pattern model best fits the Hiper GA.
    This is one of those things that I would NOT want to guess about!
  4. RFB
    RFB 5-Year Member
    1,522
    Old Florida
    FL
    After you do your homework, run an OPUS session on a known control point, or 4, with good elevations.
    Then compare.
    :coffee:
  5. JerryS
    JerryS 5-Year Member
    328
    Shelbyville, TN
    The TPSHIPER_PLUS option is the correct one for what you have.
    The HiPer+, HiPer Lite+, HiPer Pro, HiPer XT, HiPer Ga & Gb are all the same receiver differing in terms of the radio and the standard OAF file.
  6. PerfectStranger
    PerfectStranger 3-Year Member
    Aug 23, 2011
    2
    Has anyone found which OPUS antenna model best approximates the Hiper GA? I'm up against the wall with a ton of observations from a surveyor I contracted and he used the Hiper GA (Part Number: 01-860805-01 says he).
    Thanks much,
    Matt
  7. Loyal
    1,688
    I just checked the latest IGS antenna file (igs08_1644.atx) and I didn'e see it there (could have missed I suppose).
    See:
    ftp://igs.org/pub/station/general/igs08.atx
    I also looked at the latest NGS Absolute Calibration Files (see the Readjustment page), and no joy there either.
    http://beta.ngs.noaa.gov/myear/
    Beats me, it will be available when it's available I suppose.
    Sorry,
  8. Loyal
    1,688
    You might try
    Just a thought, but you might shoot an Email off to Dr. Gerald Mader at NGS HQ.
    Gerald.L.Mader@noaa.gov
    He would probably know if that antenna is currently in the calibration pipeline, and if so when it might be available to OPUS.
  9. PerfectStranger
    Aug 23, 2011
    2
    You might try
    Thanks for the help and information. Much appreciated, my friend.
    Regards,
    Matt
  10. sonofsurveyor
    sonofsurveyor 3-Year Member
    Feb 14, 2012
    1
    New Jersey
    Opus and Topcon Hiper Ga/Gb
    I have been using the Topcon Hiper Gb receivers and OPUS for the last 2 years. I contacted my equipment dealer who then contacted his Topcon Rep. to ask what Antenna Phase Center we should be using for the Hiper Ga/Gb receiver. He verified my choice which was the "TPSHiper Lite P/N 01-840802-03 Antenna+Receiver+Wireless".
  11. Denny
    Denny 3-Year Member
    Jan 31, 2013
    44
    2 things using hiper sr and results from opus
    are different then if iI use the same cors sites
    by a fair amount. Not sure just yet because of the following
    I put the 2 rtk receivers on
    a initialization bar I had from
    ashtech and shot as rover point
    the horizontal difference was about 0.008 feet
    close enough but the vertical was about 0.05 feet
    which I suspected from some preliminary field work WTF
  12. Big Al
    Big Al 5-Year Member
    Nov 2, 2010
    656
    Massachusetts
    In the picture below, taken from http://www.ngs.noaa.gov/ANTCAL/Antennas.jsp?manu=Topcon, take a look at the description text in the right most column. Does "GPS" indicate that the receiver tracks GPS satellites only, whereas "G/G" indicates that the receiver tracks both GPS and Glonass?
  13. Loyal
    1,688
    I don't think so!
    Here's the ANTEX record:
    Code:
         1.4            G                                       ANTEX VERSION / SYST
    A                                                           PCV TYPE / REFANT
    This calibration extracted from composite ngs08.atx.  See   COMMENT
    the composite file ngs08.atx for more information.          COMMENT
        END OF HEADER
        START OF ANTENNA
    TPSHIPER_PLUS   NONE                                        TYPE / SERIAL NO
    FIELD               NGS                      3    25-MAR-11 METH / BY / # / DATE
         0.0                                                    DAZI
         0.0  80.0   5.0                                        ZEN1 / ZEN2 / DZEN
         2                                                      # OF FREQUENCIES
    IGS08_1788                                                  SINEX CODE
    CONVERTED FROM RELATIVE NGS ANTENNA CALIBRATIONS            COMMENT
       G01                                                      START OF FREQUENCY
         -0.22      1.23     87.75                              NORTH / EAST / UP
       NOAZI    0.00   -0.03    0.20    0.67    0.98    1.18    1.34    1.51    1.53    1.59    1.54    1.61    1.57    1.65    1.92    2.59    3.97
       G01                                                      END OF FREQUENCY
       G02                                                      START OF FREQUENCY
         -0.78      0.11     89.45                              NORTH / EAST / UP
       NOAZI    0.00   -1.03   -1.61   -1.88   -1.89   -1.88   -1.79   -1.77   -1.91   -2.01   -2.05   -2.06   -1.83   -1.63   -1.33   -0.81   -0.05
       G02                                                      END OF FREQUENCY
        END OF ANTENNA
    Looks like an L1/L2 to me (# Frequencies 2).
  14. Big Al
    Nov 2, 2010
    656
    Massachusetts
    Any clue what G/G means?
  15. Loyal
    1,688
    No clue here...
