.tps to Rinex
Discussion in 'Surveying & Geomatics' started by jasonbrownwvps, Oct 4, 2013.
  1. jasonbrownwvps
    jasonbrownwvps 3-Year Member
    Oct 25, 2011
    21
    St. Albans, WV
    Any suggestions for converting a Topcon .tps file to rinex format for post processing through outside source. OPUS shutdown has me pulling my hair out (and no9t much to spare!)
    Jason
  2. John Hamilton
    John Hamilton 5-Year Member
    Sep 13, 2010
    1,346
    Pittsburgh, PA
    PA
    I believe teqc will convert that. Go to unavco.org and download the program. Very useful utility.
  3. TC
    TC 4-Year Member
    Apr 11, 2011
    71
    Topcon Support under Software, Software Utilities is TPS2RIN converter.
  4. jasonbrownwvps
    Oct 25, 2011
    21
    St. Albans, WV
    downloaded the TPR2RIN from Topcon and when I try to run it....it opens for a split second and then disappears. Driving me MAD!
  5. SOJ
    SOJ 4-Year Member
    Mar 16, 2012
    192
    Siskiyou County, California
    Copy a version to of TPS2RIN into a folder that your *.tps files are in then select your *.tps files and drag them onto your TPS2RIN icon and drop them. TPS2RIN will do the rest.
  6. jasonbrownwvps
    Oct 25, 2011
    21
    St. Albans, WV
    ok...that seemed to work. So...I started out with my BASE.TPS (one file)....and now I have 3 different BASE files after conversion(BASE.13G, BASE.13N and BASE.13O).
    Do I send all 3 off to post processing site?
  7. SOJ
    SOJ 4-Year Member
    Mar 16, 2012
    192
    *.13o is the raw observation file. That's the one you want to send. The *.13n is the broadcast ephemeris associated with the TPS file.
  8. Bryan Newsome
    Bryan Newsome 5-Year Member
    400
    Driftwood, TX
    send you "O" file...
    I don't remember what the "G" file covers, the "N" file is the navigation file, the "O" file (observations?) is the one for processing.
    I bow to others if they correct my nomenclature.
  9. SOJ
    SOJ 4-Year Member
    Mar 16, 2012
    192
    I think TPS2RIN separates the GLONASS ephemerides from the GPS and that is what the G file is.???
  10. Bryan Newsome
    400
    Driftwood, TX
    send your "O" file...
    SOJ is correct, the "G" file is the Glonass file.
    from the IGS.org site:
    4. THE EXCHANGE OF RINEX FILES:
    We recommend using the following naming convention for RINEX files:
    ssssdddf.yyt
    | | | | +-- t: file type:
    | | | | O: Observation file
    | | | | N: GPS Navigation file
    | | | | M: Meteorological data file
    | | | | G: GLONASS Navigation file
    | | | | L: Future Galileo Navigation file
    | | | | H: Geostationary GPS payload nav mess file
    | | | | B: Geo SBAS broadcast data file
    | | | | (separate documentation)
    | | | | C: Clock file (separate documentation)
    | | | | S: Summary file (used e.g., by IGS, not a standard!)
    | | | +--- yy: two-digit year
    | | +----- f: file sequence number/character within day
    | | daily file: f = 0
    | | hourly files:
    | | f = a: 1st hour 00h-01h; f = b: 2nd hour 01h-02h; ...
    | | f = x: 24th hour 23h-24h
    | +------- ddd: day of the year of first record
    +----------- ssss: 4-character station name designator
  11. jasonbrownwvps
    Oct 25, 2011
    21
    St. Albans, WV
    Thanks for all your help. The CSRS site seemed to work fine and solutions seem to agree with another sites (AUSPOS) horizontals locations fairly well.
  12. SOJ
    SOJ 4-Year Member
    Mar 16, 2012
    192
    :good:
    Have a great weekend!
  13. hubermar
    hubermar 3-Year Member
    May 23, 2012
    25
    North Carolina
    Would you please send me one or two of your Topcon files?
    I'd like to test its conversion using TEQC.
    Thanks,
    Mark
